Saltar al contenido principal
Casio DW-6900 Watchband Replacement
Qué necesitas
  1. Casio DW-6900 Watchband  Replacement, Watchband: paso 1, imagen 1 de 3 Casio DW-6900 Watchband  Replacement, Watchband: paso 1, imagen 2 de 3 Casio DW-6900 Watchband  Replacement, Watchband: paso 1, imagen 3 de 3
    • There are four screws— two on each side of the watch case.
    • Use the Philllips screwdriver to remove four 4.5 mm screws.
  2. Casio DW-6900 Watchband  Replacement: paso 2, imagen 1 de 2 Casio DW-6900 Watchband  Replacement: paso 2, imagen 2 de 2
    • There are two trunnions on both sides of the watch, and there are four grooves.
    • Use a small flat-blade screwdriver and push inward to remove the trunnion. And remove the strap.
  3. Casio DW-6900 Watchband  Replacement: paso 3, imagen 1 de 1
    • From the bottom of the watch, buckle the case from the main body of the watch by hand.
  4. Casio DW-6900 Watchband  Replacement: paso 4, imagen 1 de 1
    • Align the hole on the side of the case with the button on the watch and put on the new watch case.
  5. Casio DW-6900 Watchband  Replacement: paso 5, imagen 1 de 3 Casio DW-6900 Watchband  Replacement: paso 5, imagen 2 de 3 Casio DW-6900 Watchband  Replacement: paso 5, imagen 3 de 3
    • Thread the trunnion into the small hole on the strap.
    • First, snap one side of the trunnion into the hole of the watch body.
    • Use a flat-blade screwdriver to push the other end of the trunnion into the main body of the watch.
  6. Casio DW-6900 Watchband  Replacement: paso 6, imagen 1 de 2 Casio DW-6900 Watchband  Replacement: paso 6, imagen 2 de 2
    • Screw on the four screws on both sides of the watch.
Conclusión
Shaoguang He
Miembro Desde 05/10/21
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 67
Todo El Tiempo: 2,703
