Saltar al contenido principal
Casio CTK-501 Keys Replacement
Qué necesitas
  1. Casio CTK-501 Keys Replacement, Bottom Panel: paso 1, imagen 1 de 2 Casio CTK-501 Keys Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: paso 2, imagen 1 de 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: paso 3, imagen 1 de 2 Casio CTK-501 Keys Replacement: paso 3, imagen 2 de 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: paso 4, imagen 1 de 1
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: paso 5, imagen 1 de 1
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: paso 6, imagen 1 de 1
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: paso 7, imagen 1 de 1
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
Conclusión
7 personas más completaron esta guía.
Jimmy Winne
Miembro Desde 10/04/12
578 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-16, Amido Fall 2012 Miembro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Miembros
6 Guías creadas
4 comentarios
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Contestar
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - Contestar
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - Contestar
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 25,203
