Saltar al contenido principal
Casio CTK-501 Battery Connection Replacement
Qué necesitas
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: paso 1, imagen 1 de 2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: paso 2, imagen 1 de 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: paso 3, imagen 1 de 2 Casio CTK-501 Battery Connection Replacement: paso 3, imagen 2 de 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: paso 4, imagen 1 de 1
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: paso 5, imagen 1 de 1
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: paso 6, imagen 1 de 1
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: paso 7, imagen 1 de 1
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: paso 8, imagen 1 de 1
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
Conclusión
3 personas más completaron esta guía.
Jimmy Winne
Miembro Desde 10/04/12
578 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-16, Amido Fall 2012 Miembro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 5,216
