Saltar al contenido principal
Casio A158WA-1 Watch Circuit Board Replacement
Qué necesitas
  1. Casio A158WA-1 Watch Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 1
    • Remove the four screws from the back of the watch using a Phillips #00 screwdriver.
  2. Casio A158WA-1 Watch Circuit Board Replacement: paso 2, imagen 1 de 2 Casio A158WA-1 Watch Circuit Board Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the back cover and the black rubber band with tweezers.
  3. Casio A158WA-1 Watch Circuit Board Replacement: paso 3, imagen 1 de 2 Casio A158WA-1 Watch Circuit Board Replacement: paso 3, imagen 2 de 2
    • Use a pair of tweezers to pull the small metal tab and remove the interior of the watch.
  4. Casio A158WA-1 Watch Circuit Board Replacement: paso 4, imagen 1 de 2 Casio A158WA-1 Watch Circuit Board Replacement: paso 4, imagen 2 de 2
    • Use a pair of tweezers to lift the metal clasps at each corner and remove the battery holder.
  5. Casio A158WA-1 Watch Circuit Board Replacement: paso 5, imagen 1 de 1
    • Separate the LCD from the circuit board.
  6. Casio A158WA-1 Watch Circuit Board Replacement: paso 6, imagen 1 de 1
    • Remember the position of the battery for reassembly.
    • Detach the battery from the circuit board.
  7. Casio A158WA-1 Watch Circuit Board Replacement: paso 7, imagen 1 de 1
    • Attach the battery to the new circuit board.
  8. Casio A158WA-1 Watch Circuit Board Replacement: paso 8, imagen 1 de 3 Casio A158WA-1 Watch Circuit Board Replacement: paso 8, imagen 2 de 3 Casio A158WA-1 Watch Circuit Board Replacement: paso 8, imagen 3 de 3
    • Place the new circuit board behind the LCD.
  9. Casio A158WA-1 Watch Circuit Board Replacement: paso 9, imagen 1 de 2 Casio A158WA-1 Watch Circuit Board Replacement: paso 9, imagen 2 de 2
    • Reattach the battery holder and push down on the clasps at each corner.
  10. Casio A158WA-1 Watch Circuit Board Replacement: paso 10, imagen 1 de 3 Casio A158WA-1 Watch Circuit Board Replacement: paso 10, imagen 2 de 3 Casio A158WA-1 Watch Circuit Board Replacement: paso 10, imagen 3 de 3
    • Place the interior of the watch inside of the shell.
    • Put the rubber band and the lid back in their original position.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 43
Todo El Tiempo: 1,205
