Saltar al contenido principal
Casablanca W-11 Wall Control Switch Replacement
Qué necesitas
  1. Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: paso 1, imagen 1 de 3 Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: paso 1, imagen 2 de 3 Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: paso 1, imagen 3 de 3
    • Apparently W-11 is obsolete and replaced by W-32 which is also obsolete.
    • Main power switch was burned out. You can see lots of black around contacts of switch I took apart.
    • I replaced it with a rocker switch (Digikey EG1510-ND, $1 switch + $5 shipping). It's the wrong color but brown switches are hard to find.
    • New switch has on/off marking. Original switch always annoyed me because I could not tell if it was on or off.
Conclusión
To reassemble your device, follow these instructions in reverse order. Important: Buy SPST or SPDT switch or connectors won’t fit.
2 personas más completaron esta guía.
Alan Nishioka
Miembro Desde 07/17/11
3,507 Reputación
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 78
Todo El Tiempo: 5,089
