Saltar al contenido principal
Carrier 58MSA060-08 Furnace Filter Replacement
Qué necesitas
  1. Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: paso 1, imagen 1 de 2 Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: paso 1, imagen 2 de 2
    • Locate the furnace disconnect switch.
    • Flip the switch from the "ON" position to the "OFF" position.
  2. Carrier 58MSA060-08 Furnace Filter Replacement: paso 2, imagen 1 de 1
    • The filter is located in between the return duct and the main furnace unit.
  3. Carrier 58MSA060-08 Furnace Filter Replacement: paso 3, imagen 1 de 3 Carrier 58MSA060-08 Furnace Filter Replacement: paso 3, imagen 2 de 3 Carrier 58MSA060-08 Furnace Filter Replacement: paso 3, imagen 3 de 3
    • Pull the filter cover off of the duct to remove it and expose the filter.
  4. Carrier 58MSA060-08 Furnace Filter Replacement: paso 4, imagen 1 de 2 Carrier 58MSA060-08 Furnace Filter Replacement: paso 4, imagen 2 de 2
    • Examine your furnace to determine the air flow direction.
    • The Return Duct
    • The Furnace Unit
    • The air will always flow from the return duct towards the furnace unit.
    • Your old filter may also have an arrow indicator on the side.
    • The arrow's direction will indicate the air flow direction.
  5. Carrier 58MSA060-08 Furnace Filter Replacement: paso 5, imagen 1 de 3 Carrier 58MSA060-08 Furnace Filter Replacement: paso 5, imagen 2 de 3 Carrier 58MSA060-08 Furnace Filter Replacement: paso 5, imagen 3 de 3
    • Remove the old filter by pulling it out of the duct.
  6. Carrier 58MSA060-08 Furnace Filter Replacement: paso 6, imagen 1 de 3 Carrier 58MSA060-08 Furnace Filter Replacement: paso 6, imagen 2 de 3 Carrier 58MSA060-08 Furnace Filter Replacement: paso 6, imagen 3 de 3
    • Insert the new filter.
    • Pay attention to which direction the new filter should face before inserting it; make it is correct.
  7. Carrier 58MSA060-08 Furnace Filter Replacement: paso 7, imagen 1 de 2 Carrier 58MSA060-08 Furnace Filter Replacement: paso 7, imagen 2 de 2
    • Reattach the filter cover.
    • Ensure that the filter cover is securely in place.
  8. Carrier 58MSA060-08 Furnace Filter Replacement: paso 8, imagen 1 de 2 Carrier 58MSA060-08 Furnace Filter Replacement: paso 8, imagen 2 de 2
    • Turn on the furnace.
    • Flip the switch from the "OFF" position to the "ON" position.
Conclusión
Once you have completed these steps, your furnace filter replacement will be complete.
2 personas más completaron esta guía.
Alexander Ye
Miembro Desde 01/19/22
184 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 54
Ultimos 30 días: 176
Todo El Tiempo: 5,995
