Introducción
This guide removes and replaces the power cord entirely.
This is intended for cord replacement when the break is within the base. Power cords broken outside of the base, nearer the plug, use troubleshooting guide.
Qué necesitas
Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
Begin detaching the circuit board by removing four rounded top (12mm) Philips head screws (one from each corner).
Find the blue and black wires that connect to the circuit board from the power cord. Using moderate force, pull them away from their silver tabs on the circuit board.
Disconnect five metal connectors attached to the center circle - three wires from the circuit board, and two wires from the power cord.
From the circuit board, there are two white wires and one red wire to be disconnected.
From the power cord, there is a green wire, as well as two wires (one blue, one white) connected with black electrical tape near the metal.
2 personas más completaron esta guía.
