Introducción
The Turbine is integral to the Ventilator's function. A possible cause of failure during the delivered volume test is the turbine assembly itself. In this case the Turbine assembly must be removed, and either replaced with P/N 16349 or sent to manufacturer for Re-Characterization. This guide will walk through the necessary steps to remove the turbine assembly.
Qué necesitas
Paso 1 Cardinal Health Vela Ventilator Power Cable Removal
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Paso 6 Cardinal Health Vela Ventilator Battery Tray Removal
Aviso: los pasos 6-8 provienen de una guía que está marcada como "En progreso".
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
Paso 13 Blender Assembly P/N 16358A
Aviso: los pasos 13-21 provienen de una guía que está marcada como "En progreso".
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
Una persona más ha completado esta guía.
