Saltar al contenido principal
Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Cardinal Health Vela Ventilator Power Cable Removal: paso 1, imagen 1 de 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: paso 3, imagen 1 de 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 4, imagen 1 de 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Aviso: los pasos 6-8 provienen de una guía que está marcada como "En progreso".
    Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Cardinal Health Vela Ventilator Battery Tray Removal: paso 6, imagen 1 de 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 8, imagen 1 de 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
  6. Aviso: los pasos 13-21 provienen de una guía que está marcada como "En progreso".
    Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Blender Assembly P/N 16358A: paso 13, imagen 1 de 1
    • If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
    • If the rear panel is installed, disconnect the 40-pin ribbon cable from the SVGA out PCB.
  7. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 15, imagen 1 de 1
    • If the front panel is installed, disconnect the green oxygen nebulizer tube.
    • Disconnect the:
    • -J301, 12-Pin Connector to J301 on the main PCB
    • From the blender PCB
  8. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 17, imagen 1 de 1
    • Remove the bottom strip ambient air inlet filter by pinching and pulling it out.
  9. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 18, imagen 1 de 1
    • Remove the three Phillips pan-head screws on the right side of the rear panel.
  10. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 19, imagen 1 de 1
    • The assembly should now be free to remove. As you remove the unit use your needle-nose pliers to disconnect the oxygen diffuser tube as you remove the blender assembly.
  11. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 20, imagen 1 de 2 Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 20, imagen 2 de 2
    • If the exhalation valve assembly is installed, disconnect:
    • J3 [2-pin (blue connection)]
    • To the oxygen inlet solenoid on the blender assembly.
    • J4 [2-pin (red connection)]
    • To the Nebulizer solenoid assembly on upper rear of blender.
    • For Instillation follow steps in reverse order.
    • Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
  12. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: paso 23, imagen 1 de 1
    • Remove the 5 Phillips pan-head mounting screws.
    • Disconnect the gray silicone intake and output elbows by gently pulling them out from the muffler tubes.
    • The Turbine/Muffler Assembly should now be free to lift off the manifold base.
    • Gently pull up on the elbows to remove
    • To Install P/N 16350 "Turbine/Muffler Assembly" repeat the steps in reverse order.
Conclusión
Una persona más ha completado esta guía.
Tanner Hillman
Miembro Desde 04/10/20
370 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S7-G22, Paton Spring 2020 Miembro de Cal Poly, Team S7-G22, Paton Spring 2020
CPSU-PATON-S20S7G22
1 Miembro
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 283
