Introducción
A failure on the "Delivered Volume Test" can signify dirty filters needing replacement. Knowing how to replace these is vital to the Ventilator's function. This guide will run through all the necessary steps including the removal of the:
-Power cable
-Top Panel
-Battery Tray
-Left Panel
-Blender Assembly
And finally the Turbine/Muffler Assembly itself
Qué necesitas
Paso 1 Cardinal Health Vela Ventilator Power Cable Removal
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Paso 6 Cardinal Health Vela Ventilator Battery Tray Removal
Aviso: los pasos 6-8 provienen de una guía que está marcada como "En progreso".
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
Paso 13 Blender Assembly P/N 16358A
Aviso: los pasos 13-21 provienen de una guía que está marcada como "En progreso".
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
Remove the six Phillips pan-head screws on the cover of the filter
