Introducción
The left panel is structurally significant to the ventilator but is not fixed to any other components. Therefore it is necessary to remove the left panel for a vast majority of service to be done on internal components of the ventilator. You will need a Phillips screwdriver to complete this guide. This part is strictly structural, however it needs to be removed to access many of the parts inside.
Qué necesitas
Paso 1 Cardinal Health Vela Ventilator Power Cable Removal
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Paso 6 Cardinal Health Vela Ventilator Battery Tray Removal
Aviso: los pasos 6-8 provienen de una guía que está marcada como "En progreso".
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
