Saltar al contenido principal
Cardinal Health Vela Ventilator Left Panel Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Power Cable Removal: paso 1, imagen 1 de 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: paso 3, imagen 1 de 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Left Panel Replacement: paso 4, imagen 1 de 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Aviso: los pasos 6-8 provienen de una guía que está marcada como "En progreso".
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Battery Tray Removal: paso 6, imagen 1 de 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Left Panel Replacement: paso 8, imagen 1 de 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
Conclusión
Tanner Hillman
Miembro Desde 04/10/20
370 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S7-G22, Paton Spring 2020 Miembro de Cal Poly, Team S7-G22, Paton Spring 2020
CPSU-PATON-S20S7G22
1 Miembro
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 107
