Saltar al contenido principal
Cardinal Health Vela Ventilator Exhalation Valve Body Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
Documento destacado
  1. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement, Exhalation Valve Body: paso 1, imagen 1 de 1
    • Use a screwdriver to remove the two Phillips #0 screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 3, imagen 1 de 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 4, imagen 1 de 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 6, imagen 1 de 1
    • Use your Phillips #0 screwdriver to unscrew the four Phillips screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 8, imagen 1 de 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
  6. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 9, imagen 1 de 1
    • Remove the two Phillips countersink screws from the right side of the rear panel.
  7. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 10, imagen 1 de 1
    • Remove the single Phillips countersink screw in the upper front of the right panel.
  8. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 11, imagen 1 de 1
    • Remove the single Phillips screw in the lower center of the right panel.
  9. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 12, imagen 1 de 1
    • Gently lift out the panel and the power PCB. Lay the panel flat and make the following disconnections:
    • Remove the 2 Phillips countersink screws at the rear of the left panel.
    • Remove the 1 Phillips countersink screw in the upper front of the left panel.
    • Lift out the left panel.
    • Disconnect the following from the main PCB:
    • JP2 40-pin ribbon cable to JP1 on the SVGA out PCB
    • J301 12-pin to J301 on the blender PCB
  10. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 15, imagen 1 de 1
    • Disconnect the green oxygen nebulizer tube
    • Remove the 2 Phillips pan-head screws behind the front panel at the lower left and right.
    • Disconnect the 1/8” silicone tube #4 from P2 on the exhalation differential transducer.
    • Disconnect the 1/8” silicone tube #5 from P1 on the exhalation differential transducer.
    • Disconnect the 1/8” silicone tube #1 from the turbine.
    • Disconnect the 1/16” silicone tube from the front ports of the turbine outlet auto-zero solenoid that goes to the main tubing harness.
    • Disconnect the 1/16” silicone tube from the turbine inlet auto-zero solenoid that goes to the turbine.
    • Disconnect the 1/16” silicone tube from the airway pressure auto-zero solenoid that goes to the exhalation valve receptacle.
  11. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 17, imagen 1 de 1
    • Disconnect the following from the FIO2 monitoring PCB:
    • J2 2-pin (clear conn.) to oxygen sensor
    • J3 2-pin (blue conn.) to oxygen inlet solenoid on blender assembly
    • J4 2-pin (red conn.) to nebulizer solenoid assembly on upper rear of blender
  12. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: paso 19, imagen 1 de 1
    • Remove two Phillips pan-head screws on the valve cover.
    • Lift out the exhalation valve assembly.
Conclusión
Documentos Adjuntos
Ethan Nikcevich
Miembro Desde 04/07/20
649 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S11-G22, Paton Spring 2020 Miembro de Cal Poly, Team S11-G22, Paton Spring 2020
CPSU-PATON-S20S11G22
2 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 289
