Saltar al contenido principal
Carburetor Cleaning
Qué necesitas
  1. Carburetor Cleaning, Air Filter: paso 1, imagen 1 de 3 Carburetor Cleaning, Air Filter: paso 1, imagen 2 de 3 Carburetor Cleaning, Air Filter: paso 1, imagen 3 de 3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: paso 2, imagen 1 de 1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: paso 3, imagen 1 de 3 Carburetor Cleaning, Carburetor Cleaning: paso 3, imagen 2 de 3 Carburetor Cleaning, Carburetor Cleaning: paso 3, imagen 3 de 3
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: paso 4, imagen 1 de 2 Carburetor Cleaning: paso 4, imagen 2 de 2
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: paso 5, imagen 1 de 1
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
Conclusión
2 personas más completaron esta guía.
Ethan Narad
Miembro Desde 04/19/18
529 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S25-G15, Maness Spring 2018 Miembro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 1,572
