Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Car Seat Belt Stopper Replacement
Qué necesitas
    1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: paso 1, imagen 1 de 1
      • Use a cloth to wipe away any debris from the area.
      Pregunta a FixBot
      Agregar Comentario
    2. Car Seat Belt Stopper Replacement: paso 2, imagen 1 de 1
      • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
      • Separate the replacement stopper if it has come assembled.
      Pregunta a FixBot
      Agregar Comentario
    3. Car Seat Belt Stopper Replacement: paso 3, imagen 1 de 1
      • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
      • Push the side of the seat belt button with the needle or point into your desired location.
      • It may require a small amount of force.
      Pregunta a FixBot
      Agregar Comentario
    4. Car Seat Belt Stopper Replacement: paso 4, imagen 1 de 1
      • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
      • Fasten the two parts of the button together and squeeze for a secure fit.
      • You may hear a "snap" or "click" when they are fastened together.
      Pregunta a FixBot
      Agregar Comentario
    5. Car Seat Belt Stopper Replacement: paso 5, imagen 1 de 1
      • Check the position of the replacement stopper for a comfortable fit.
      Pregunta a FixBot
      Agregar Comentario
    6. Car Seat Belt Stopper Replacement: paso 6, imagen 1 de 1
      • Now you can use the seat belt buckle without it falling down!
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Changing your positioning of replacement can be used to your liking.
Una persona más ha completado esta guía.
Zhong Chu
Miembro Desde 04/23/24
137 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-1, Whithaus Spring 2024 Miembro de UC Davis, Team 4-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G1
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 36
Ultimos 30 días: 173
Todo El Tiempo: 3,264
