Saltar al contenido principal
Capresso Perfectea 260 Motherboard Replacement
Qué necesitas
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: paso 2, imagen 1 de 2 Capresso Perfectea 260 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: paso 4, imagen 1 de 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: paso 5, imagen 1 de 2 Capresso Perfectea 260 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: paso 6, imagen 1 de 1
    • Lift the motherboard out of the device
Conclusión
Rohin Chander
Miembro Desde 04/14/15
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-17, Maness Spring 2015 Miembro de Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 238
