Saltar al contenido principal
Capresso Infinity Power Cord Replacement
Qué necesitas
  1. Capresso Infinity Power Cord Replacement, Metal Outside Casing: paso 1, imagen 1 de 2 Capresso Infinity Power Cord Replacement, Metal Outside Casing: paso 1, imagen 2 de 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Power Cord Replacement: paso 2, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 2, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 2, imagen 3 de 3
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Power Cord Replacement: paso 3, imagen 1 de 2 Capresso Infinity Power Cord Replacement: paso 3, imagen 2 de 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Power Cord Replacement: paso 4, imagen 1 de 2 Capresso Infinity Power Cord Replacement: paso 4, imagen 2 de 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Power Cord Replacement: paso 5, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 5, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 5, imagen 3 de 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Power Cord Replacement: paso 6, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 6, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 6, imagen 3 de 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Power Cord Replacement: paso 7, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 7, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 7, imagen 3 de 3
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Power Cord Replacement: paso 8, imagen 1 de 2 Capresso Infinity Power Cord Replacement: paso 8, imagen 2 de 2
    • Remove the time/on switch by pulling upwards.
  9. Capresso Infinity Power Cord Replacement, Power Cord: paso 9, imagen 1 de 3 Capresso Infinity Power Cord Replacement, Power Cord: paso 9, imagen 2 de 3 Capresso Infinity Power Cord Replacement, Power Cord: paso 9, imagen 3 de 3
    • Remove two 13.60mm T10 screws.
    • A white, flat plastic piece will have come loose. Place this to the side for reassembly.
  10. Capresso Infinity Power Cord Replacement: paso 10, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 10, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 10, imagen 3 de 3
    • Using a Flathead screwdriver loosen the two screws connecting the white and black wire to the plastic box.
    • Do not remove the screws from the box, but loosen them enough to disconnect the black and white wire.
  11. Capresso Infinity Power Cord Replacement: paso 11, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 11, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 11, imagen 3 de 3
    • Originally attached to the inside of the outer casing, the green wire needs to be fed through the zip tie which keeps it in place.
    • Lift up on the zip tie far enough to create a space to feed the green wire through.
    • Place the zip tie back around the column that you lifted it from.
    • All three wires that comprise the power cord should be detached from the coffee grinder.
  12. Capresso Infinity Power Cord Replacement: paso 12, imagen 1 de 3 Capresso Infinity Power Cord Replacement: paso 12, imagen 2 de 3 Capresso Infinity Power Cord Replacement: paso 12, imagen 3 de 3
    • Feed the wires through the small hole at the bottom of the coffee grinder where the external power cord is located.
    • Once the power cord is free of the coffee grinder, you are able to put in the new cord.
Conclusión
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 507
