Saltar al contenido principal
Capresso Infinity Outside Casing Replacement
Qué necesitas
  1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: paso 1, imagen 1 de 2 Capresso Infinity Outside Casing Replacement, Metal Outside Casing: paso 1, imagen 2 de 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Outside Casing Replacement: paso 2, imagen 1 de 3 Capresso Infinity Outside Casing Replacement: paso 2, imagen 2 de 3 Capresso Infinity Outside Casing Replacement: paso 2, imagen 3 de 3
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Outside Casing Replacement: paso 3, imagen 1 de 2 Capresso Infinity Outside Casing Replacement: paso 3, imagen 2 de 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Outside Casing Replacement: paso 4, imagen 1 de 2 Capresso Infinity Outside Casing Replacement: paso 4, imagen 2 de 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Outside Casing Replacement: paso 5, imagen 1 de 3 Capresso Infinity Outside Casing Replacement: paso 5, imagen 2 de 3 Capresso Infinity Outside Casing Replacement: paso 5, imagen 3 de 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Outside Casing Replacement: paso 6, imagen 1 de 3 Capresso Infinity Outside Casing Replacement: paso 6, imagen 2 de 3 Capresso Infinity Outside Casing Replacement: paso 6, imagen 3 de 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Outside Casing Replacement: paso 7, imagen 1 de 3 Capresso Infinity Outside Casing Replacement: paso 7, imagen 2 de 3 Capresso Infinity Outside Casing Replacement: paso 7, imagen 3 de 3
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Outside Casing Replacement: paso 8, imagen 1 de 2 Capresso Infinity Outside Casing Replacement: paso 8, imagen 2 de 2
    • Remove the time/on switch by pulling upwards.
Conclusión
Nina Mackin
Miembro Desde 10/09/18
528 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 1,465
