Saltar al contenido principal
Cap Restoration
Qué necesitas
  1. Cap Restoration, Cap Restoration: paso 1, imagen 1 de 3 Cap Restoration, Cap Restoration: paso 1, imagen 2 de 3 Cap Restoration, Cap Restoration: paso 1, imagen 3 de 3
    • Wash the cap using an old toothbrush to remove residue and stains.
    • You can use dish soap or detergent to assist with the cleaning process.
  2. Cap Restoration: paso 2, imagen 1 de 1
    • Pat dry the cap with a towel to remove any excess water.
  3. Cap Restoration: paso 3, imagen 1 de 2 Cap Restoration: paso 3, imagen 2 de 2
    • Apply the hairspray to the front and inside of the cap.
  4. Cap Restoration: paso 4, imagen 1 de 1
    • Place plastic bags into the cap ensuring enough bags are used to give the cap some shape.
  5. Cap Restoration: paso 5, imagen 1 de 2 Cap Restoration: paso 5, imagen 2 de 2
    • Use a bowl or small pot to add pressure to the plastic bags and hold them in place.
    • Tighten the clip or snaps of the cap to fix the pot/bowl and plastic bags into place.
  6. Cap Restoration: paso 6, imagen 1 de 1
    • Set the cap aside to dry naturally. You can use an indoor fan to assist with this process.
    • Do not leave outside or near heater to dry.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 72
Ultimos 30 días: 322
Todo El Tiempo: 18,100
