Saltar al contenido principal
Canon ZR70MC LCD Component Replacement
Qué necesitas
  1. Canon ZR70MC LCD Component Replacement, Front Panel: paso 1, imagen 1 de 2 Canon ZR70MC LCD Component Replacement, Front Panel: paso 1, imagen 2 de 2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC LCD Component Replacement: paso 2, imagen 1 de 1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC LCD Component Replacement: paso 3, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 3, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 3, imagen 3 de 3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC LCD Component Replacement: paso 4, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 4, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 4, imagen 3 de 3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC LCD Component Replacement: paso 5, imagen 1 de 2 Canon ZR70MC LCD Component Replacement: paso 5, imagen 2 de 2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC LCD Component Replacement: paso 6, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 6, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 6, imagen 3 de 3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC LCD Component Replacement: paso 7, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 7, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 7, imagen 3 de 3
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
  8. Canon ZR70MC LCD Component Replacement, LCD screen: paso 8, imagen 1 de 3 Canon ZR70MC LCD Component Replacement, LCD screen: paso 8, imagen 2 de 3 Canon ZR70MC LCD Component Replacement, LCD screen: paso 8, imagen 3 de 3
    • Open the LCD screen.
    • Locate and remove the 2.7 mm screw on the bottom of the LCD monitor.
  9. Canon ZR70MC LCD Component Replacement: paso 9, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 9, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 9, imagen 3 de 3
    • Turn the LCD monitor so that the screen is facing down.
    • There is a 2.7 mm screw on the LCD monitor where the monitor is connected to the main body of the camcorder. Remove the 2.7 mm screw.
  10. Canon ZR70MC LCD Component Replacement: paso 10, imagen 1 de 2 Canon ZR70MC LCD Component Replacement: paso 10, imagen 2 de 2
    • Turn the LCD monitor so that the screen is facing up.
    • There is a 2.7 mm screw located where the LCD monitor is connected to the main body of the camcorder. Remove the 2.7 mm screw.
  11. Canon ZR70MC LCD Component Replacement: paso 11, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 11, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 11, imagen 3 de 3
    • Now that all the screws are removed, use the plastic opening tool to gently pry the LCD monitor case open.
  12. Canon ZR70MC LCD Component Replacement: paso 12, imagen 1 de 3 Canon ZR70MC LCD Component Replacement: paso 12, imagen 2 de 3 Canon ZR70MC LCD Component Replacement: paso 12, imagen 3 de 3
    • Use tweezers to remove the wire connections that hold the LCD screen in place.
    • Remove the entire LCD screen.
Conclusión
Una persona más ha completado esta guía.
khalid clarke
Miembro Desde 09/26/17
824 Reputación
7 Guías creadas
Equipo
USF Tampa, Team S13-G2, Boczar Fall 2017 Miembro de USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 156
