Saltar al contenido principal
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: paso 1, imagen 1 de 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: paso 1, imagen 2 de 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: paso 1, imagen 3 de 3
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: paso 2, imagen 1 de 3 Canon Vixia HF20 Camcorder Strap Replacement: paso 2, imagen 2 de 3 Canon Vixia HF20 Camcorder Strap Replacement: paso 2, imagen 3 de 3
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: paso 3, imagen 1 de 1
    • Once the fit is adjusted, secure by closing the padded strap.
Linea de Meta
Una persona más ha completado esta guía.
Taylor Morris
Miembro Desde 03/05/15
225 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 550
