Saltar al contenido principal
Canon Vixia HF20 Attachment Port for Optional Accessory Replacement
Qué necesitas
  1. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement, Attachment Port for Optional Accessory: paso 1, imagen 1 de 1
    • Remove the mini advanced shoe from the top of the camcorder.
  2. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: paso 2, imagen 1 de 1
    • Unscrew the four 6 millimeter screws with the Phillips screwdriver.
  3. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: paso 3, imagen 1 de 1
    • Carefully remove the silver plate with needle nose pliers.
    • Clean the silver plate with isopropyl alcohol and a cotton swab to remove any debris.
  4. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: paso 4, imagen 1 de 1
    • Reinsert the silver plate and the four 6 mm screws and screw them securely into their holes.
Conclusión
Una persona más ha completado esta guía.
Taylor Morris
Miembro Desde 03/05/15
225 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 467
