Saltar al contenido principal
Canon Vixia HF S10 Camcorder LCD Screen Replacement
Qué necesitas
  1. Canon Vixia HF S10 Camcorder LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
  2. Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 2, imagen 1 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 2, imagen 2 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 2, imagen 3 de 3
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
  3. Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 3, imagen 1 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 3, imagen 2 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 3, imagen 3 de 3
    • Using your fingers, remove the black plastic covering. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.5 mm Phillips screw located at the top of the screw hinge.
    • Using your fingers, remove the panel from the base of the camcorder.
  4. Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 4, imagen 1 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 4, imagen 2 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 4, imagen 3 de 3
    • Remove the 2x2.5 mm screw from the right side of the plastic case surrounding the LCD screen.
    • Flip over the plastic case and remove the 2x2.5 mm screw.
    • Remove the two 2x2.5 mm screws from the front plastic case.
  5. Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 5, imagen 1 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 5, imagen 2 de 3 Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, pry off the plastic case surrounding the LCD screen.
    • Remove the two 1x2.5 mm screws from the motherboard on the back of the LCD screen.
    • Gently pull off the motherboard from the LCD screen.
    • Be aware of the orange tab when seperating the motherboard from the LCD screen.
  6. Canon Vixia HF S10 Camcorder LCD Screen Replacement: paso 6, imagen 1 de 1
    • Using your fingers, remove the LCD screen.
Conclusión
Una persona más ha completado esta guía.
Karina
Miembro Desde 03/03/15
163 Reputación
1 Guía escrita
2 comentarios
Not enough detail to be really useful. For example,doesn't mention how to reconnect the ribbon strip. To be fair, no one else says how to be sure it's connected properly either.
John - Contestar
The trick to reconnecting the orange ribbon is to bend back the ribbon from its natural position so it sticks out a bit then to put the plastic body almost back in position, leaving the gap open like a partially opened book. The ribbon and socket should be almost aligned. The gap should be just enough to see in and poke about with a small tweezers. I needed a decent light and glasses to carefully align the ribbon into its receptacle. I used a small fine pair of tweezers to push (not grab!) the ribbon into place. Make sure the ribbon is correctly inserted and aligned then carefully gently flip the securing clip with the the tweezer and moving along the clip push it gently to secure the ribbon. Dont push too hard, it wont help! Next carefully manipulate the shell over the main body making sure it is aligned at back of the camera with the screw holes all lined up. Put just a couple of screws in to stabilize the loose shell then pop in the battery to check operation of the screen and buttons.
Dominic Oskis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 2,387
