Saltar al contenido principal
Canon Vixia HF S10 Camcorder Audio Replacement
Qué necesitas
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: paso 1, imagen 1 de 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: paso 1, imagen 2 de 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: paso 1, imagen 3 de 3
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: paso 2, imagen 1 de 3 Canon Vixia HF S10 Camcorder Audio Replacement: paso 2, imagen 2 de 3 Canon Vixia HF S10 Camcorder Audio Replacement: paso 2, imagen 3 de 3
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: paso 3, imagen 1 de 3 Canon Vixia HF S10 Camcorder Audio Replacement: paso 3, imagen 2 de 3 Canon Vixia HF S10 Camcorder Audio Replacement: paso 3, imagen 3 de 3
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
Conclusión
Clint
Miembro Desde 03/03/15
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 400
