Saltar al contenido principal
Canon Vixia HF R70 Top Panel Replacement
Qué necesitas
  1. Canon Vixia HF R70 Top Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Top Panel Replacement: paso 2, imagen 1 de 1
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Top Panel Replacement: paso 3, imagen 1 de 2 Canon Vixia HF R70 Top Panel Replacement: paso 3, imagen 2 de 2
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Top Panel Replacement, Wrist Strap: paso 4, imagen 1 de 1
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Top Panel Replacement: paso 5, imagen 1 de 1
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Top Panel Replacement: paso 6, imagen 1 de 1
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Top Panel Replacement: paso 7, imagen 1 de 2 Canon Vixia HF R70 Top Panel Replacement: paso 7, imagen 2 de 2
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Top Panel Replacement: paso 8, imagen 1 de 1
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Top Panel Replacement, Side Panel: paso 9, imagen 1 de 2 Canon Vixia HF R70 Top Panel Replacement, Side Panel: paso 9, imagen 2 de 2
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Top Panel Replacement: paso 10, imagen 1 de 3 Canon Vixia HF R70 Top Panel Replacement: paso 10, imagen 2 de 3 Canon Vixia HF R70 Top Panel Replacement: paso 10, imagen 3 de 3
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Top Panel Replacement: paso 11, imagen 1 de 2 Canon Vixia HF R70 Top Panel Replacement: paso 11, imagen 2 de 2
    • Gently remove the side panel by pushing it up from the bottom.
  12. Canon Vixia HF R70 Top Panel Replacement, Top Panel: paso 12, imagen 1 de 2 Canon Vixia HF R70 Top Panel Replacement, Top Panel: paso 12, imagen 2 de 2
    • Disconnect the wires by inserting the plastic opening tool into the small slit.
    • Begin to push upward with the plastic opening tool, disconnecting the two compartments.
  13. Canon Vixia HF R70 Top Panel Replacement: paso 13, imagen 1 de 3 Canon Vixia HF R70 Top Panel Replacement: paso 13, imagen 2 de 3 Canon Vixia HF R70 Top Panel Replacement: paso 13, imagen 3 de 3
    • Disconnect the four ZIF connectors by grasping the connector firmly and pulling gently.
  14. Canon Vixia HF R70 Top Panel Replacement: paso 14, imagen 1 de 1
    • Locate and remove the two 3mm Phillips #00 screws on the side of the camera where the side panel was removed.
  15. Canon Vixia HF R70 Top Panel Replacement: paso 15, imagen 1 de 1
    • Turn the camera over to the side with the LCD screen, and open the screen.
    • Locate and remove the three 5mm Phillips #00 screws holding the top panel in place.
  16. Canon Vixia HF R70 Top Panel Replacement: paso 16, imagen 1 de 3 Canon Vixia HF R70 Top Panel Replacement: paso 16, imagen 2 de 3 Canon Vixia HF R70 Top Panel Replacement: paso 16, imagen 3 de 3
    • Pull the panel up and away until it is removed completely.
Conclusión
Equipo
USF Tampa, Team S2-G2, Nance Spring 2017 Miembro de USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 187
