Saltar al contenido principal
Introducción
This guide will show you how to access and replace the lens of the camcorder. It will also act as a prerequisite to most of the internal components.
Partes
No se especificaron partes.
  1. Remove the strap by undoing the Velcro and pulling it through the thread points. Remove the external battery pack by pressing down on the slide release and sliding it out.
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Remove the three 5mm Phillips #000 screws on the bottom of the device. Remove the three 5mm Phillips #000 screws on the bottom of the device.
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. On the side of the device, remove the following Phillips #000 screws: One 3mm screw
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Remove the panel opposite the display by pulling up perpendicular to the side. Remove the panel opposite the display by pulling up perpendicular to the side.
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  7. Remove the three 4mm Phillips #000 screws shown. There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  8. Using tweezers, disconnect this ribbon cable by pulling straight out. Using tweezers, disconnect this ribbon cable by pulling straight out. Using tweezers, disconnect this ribbon cable by pulling straight out.
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  9. Repeat step seven (7) for the remaining three wires shown. Repeat step seven (7) for the remaining three wires shown. Repeat step seven (7) for the remaining three wires shown.
    • Repeat step seven (7) for the remaining three wires shown.
  10. Grasp the top of the camera and pull straight up to remove the top panel. Grasp the top of the camera and pull straight up to remove the top panel. Grasp the top of the camera and pull straight up to remove the top panel.
    • Grasp the top of the camera and pull straight up to remove the top panel.
  11. Remove the 5mm Phillips #000 screw on top of the inner case.
    • Remove the 5mm Phillips #000 screw on top of the inner case.
  12. Remove the two 5mm Phillips #000 screws near the display panel. Remove the two 5mm Phillips #000 screws near the display panel.
    • Remove the two 5mm Phillips #000 screws near the display panel.
  13. Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out. Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
    • Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
  14. Remove the lens cover by pulling straight away from the body. Remove the lens cover by pulling straight away from the body.
    • Remove the lens cover by pulling straight away from the body.
  15. Remove the three 6mm Phillips #000 screws shown. Remove the three 6mm Phillips #000 screws shown.
    • Remove the three 6mm Phillips #000 screws shown.
  16. Remove the lens by pulling straight away from the main body. Be aware of the small rubber gasket around the lens as it may come loose.
    • Remove the lens by pulling straight away from the main body.
    • Be aware of the small rubber gasket around the lens as it may come loose.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 51
