Saltar al contenido principal
Canon Vixia HF R600 LCD screen Replacement
Qué necesitas
  1. Canon Vixia HF R600 LCD screen Replacement, Handstrap: paso 1, imagen 1 de 2 Canon Vixia HF R600 LCD screen Replacement, Handstrap: paso 1, imagen 2 de 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 LCD screen Replacement: paso 2, imagen 1 de 2 Canon Vixia HF R600 LCD screen Replacement: paso 2, imagen 2 de 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 LCD screen Replacement, Battery: paso 3, imagen 1 de 2 Canon Vixia HF R600 LCD screen Replacement, Battery: paso 3, imagen 2 de 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 LCD screen Replacement, Casing: paso 4, imagen 1 de 2 Canon Vixia HF R600 LCD screen Replacement, Casing: paso 4, imagen 2 de 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 LCD screen Replacement: paso 5, imagen 1 de 2 Canon Vixia HF R600 LCD screen Replacement: paso 5, imagen 2 de 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 LCD screen Replacement: paso 6, imagen 1 de 2 Canon Vixia HF R600 LCD screen Replacement: paso 6, imagen 2 de 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 LCD screen Replacement, LCD Screen: paso 7, imagen 1 de 1
    • Remove the LCD display from the camera body.
  8. Canon Vixia HF R600 LCD screen Replacement: paso 8, imagen 1 de 3 Canon Vixia HF R600 LCD screen Replacement: paso 8, imagen 2 de 3 Canon Vixia HF R600 LCD screen Replacement: paso 8, imagen 3 de 3
    • Rotate the display hinge to reveal two 4mm Phillips #00 screws.
    • Before removing, use the plastic opening tool to pry apart the plastic hinge cover.
    • Remove the cover.
  9. Canon Vixia HF R600 LCD screen Replacement: paso 9, imagen 1 de 3 Canon Vixia HF R600 LCD screen Replacement: paso 9, imagen 2 de 3 Canon Vixia HF R600 LCD screen Replacement: paso 9, imagen 3 de 3
    • Remove the two 4mm Phillips #00 screws.
    • Pull the LCD display back cover to reveal the motherboard covering the screen.
    • Remove one more 4mm Phillips #00 screw.
  10. Canon Vixia HF R600 LCD screen Replacement: paso 10, imagen 1 de 3 Canon Vixia HF R600 LCD screen Replacement: paso 10, imagen 2 de 3 Canon Vixia HF R600 LCD screen Replacement: paso 10, imagen 3 de 3
    • Pull the screen protector away from the LCD display.
    • Use a plastic opening tool to lift the ribbon connector tab.
    • The LCD display can now be replaced!
Conclusión
Una persona más ha completado esta guía.
Brian Luna
Miembro Desde 02/10/16
483 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 14-4, Lacy Spring 2016 Miembro de USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Miembros
16 Guías creadas
6 comentarios
Where did you find the replacement LCD screen at? Specifically I am looking for the Vixia HF M41A version
Jeff Onsrud - Contestar
I can’t find the replacement lcd for my model canon vixia hf R600, can you point me in the right direction?
Seth Flake - Contestar
Gotta hf r800 and need screen, any ideas where?
Sean - Contestar
Very nice step by step guidance. Where can I find the Replacement lcd screen for Canon Vixia HFR 600 camera. Will appreciate that!
Thanks!
shelaindrab - Contestar
I have a Canon Vixia HF R52, and with all my research it looks like all of these are the same LCD: HF-R52, HF-R82, HF-R600.....and maybe even the HF-R48, and HF-R406, and HF-R706.
pe.labs - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 2,257
