Saltar al contenido principal
Canon Vixia HF R600 Camera Lens Replacement
Qué necesitas
  1. Canon Vixia HF R600 Camera Lens Replacement, Handstrap: paso 1, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement, Handstrap: paso 1, imagen 2 de 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Camera Lens Replacement: paso 2, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement: paso 2, imagen 2 de 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Camera Lens Replacement, Battery: paso 3, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement, Battery: paso 3, imagen 2 de 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Camera Lens Replacement, Casing: paso 4, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement, Casing: paso 4, imagen 2 de 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Camera Lens Replacement: paso 5, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement: paso 5, imagen 2 de 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Camera Lens Replacement: paso 6, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement: paso 6, imagen 2 de 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: paso 7, imagen 1 de 3 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: paso 7, imagen 2 de 3 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: paso 7, imagen 3 de 3
    • Remove one 5mm Phillips PH#00 screw from the top of the camera.
    • Pull away the plastic shutter casing; this contains the microphone.
    • Using the plastic opening tool or something similar, carefully disconnect the white 4 pin connector to remove the shutter casing.
  8. Canon Vixia HF R600 Camera Lens Replacement: paso 8, imagen 1 de 2 Canon Vixia HF R600 Camera Lens Replacement: paso 8, imagen 2 de 2
    • Remove the three 5mm Phillips PH#00 screws surrounding the camera lens.
    • Pull the lens off of the camera and replace.
Conclusión
2 personas más completaron esta guía.
Brian Luna
Miembro Desde 02/10/16
483 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 14-4, Lacy Spring 2016 Miembro de USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Miembros
16 Guías creadas
Un comentario
I think you need a part, the lens..... Which is what I also need, which is why I'm here..... Now, if I could just figure out where to get a lens your tutorial would be helpful.
dannyknappy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 609
