Introducción
If the lens cover on your camera will not open or close it could be caused by debris blocking the mechanism or a broken mechanism component. This guide will show you how to remove the lens cover from your camera so you can clean or repair it.
Qué necesitas
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Casi Terminas!
Conclusión
