Saltar al contenido principal
Canon Vixia HF R500 Disassembly
Qué necesitas
  1. Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: paso 1, imagen 1 de 2 Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: paso 1, imagen 2 de 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  2. Canon Vixia HF R500 Disassembly: paso 2, imagen 1 de 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  3. Canon Vixia HF R500 Disassembly: paso 3, imagen 1 de 1
    • Remove the side piece plate.
  4. Canon Vixia HF R500 Disassembly: paso 4, imagen 1 de 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  5. Canon Vixia HF R500 Disassembly: paso 5, imagen 1 de 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  6. Canon Vixia HF R500 Disassembly: paso 6, imagen 1 de 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  7. Canon Vixia HF R500 Disassembly: paso 7, imagen 1 de 3 Canon Vixia HF R500 Disassembly: paso 7, imagen 2 de 3 Canon Vixia HF R500 Disassembly: paso 7, imagen 3 de 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  8. Canon Vixia HF R500 Disassembly: paso 8, imagen 1 de 1
    • Remove the top piece.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 661
