Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon Selphy CP910 Printer Body Replacement
Qué necesitas
  1. Canon Selphy CP910 Printer Body Replacement, Body: paso 1, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement, Body: paso 1, imagen 2 de 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
    Pregunta a FixBot
    Agregar Comentario
  2. Canon Selphy CP910 Printer Body Replacement: paso 2, imagen 1 de 3 Canon Selphy CP910 Printer Body Replacement: paso 2, imagen 2 de 3 Canon Selphy CP910 Printer Body Replacement: paso 2, imagen 3 de 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
    Pregunta a FixBot
    Agregar Comentario
  3. Canon Selphy CP910 Printer Body Replacement: paso 3, imagen 1 de 3 Canon Selphy CP910 Printer Body Replacement: paso 3, imagen 2 de 3 Canon Selphy CP910 Printer Body Replacement: paso 3, imagen 3 de 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
    Pregunta a FixBot
    Agregar Comentario
  4. Canon Selphy CP910 Printer Body Replacement: paso 4, imagen 1 de 3 Canon Selphy CP910 Printer Body Replacement: paso 4, imagen 2 de 3 Canon Selphy CP910 Printer Body Replacement: paso 4, imagen 3 de 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
    Pregunta a FixBot
    Agregar Comentario
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: paso 5, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement, Printer Body: paso 5, imagen 2 de 2
    • Use the PH1 screw driver to remove the three screws on the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  6. Canon Selphy CP910 Printer Body Replacement: paso 6, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement: paso 6, imagen 2 de 2
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
    Pregunta a FixBot
    Agregar Comentario
  7. Canon Selphy CP910 Printer Body Replacement: paso 7, imagen 1 de 3 Canon Selphy CP910 Printer Body Replacement: paso 7, imagen 2 de 3 Canon Selphy CP910 Printer Body Replacement: paso 7, imagen 3 de 3
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  8. Canon Selphy CP910 Printer Body Replacement: paso 8, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement: paso 8, imagen 2 de 2
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
    Pregunta a FixBot
    Agregar Comentario
  9. Canon Selphy CP910 Printer Body Replacement: paso 9, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement: paso 9, imagen 2 de 2
    • Separate the motherboard from the main hard drive.
    Pregunta a FixBot
    Agregar Comentario
  10. Canon Selphy CP910 Printer Body Replacement: paso 10, imagen 1 de 3 Canon Selphy CP910 Printer Body Replacement: paso 10, imagen 2 de 3 Canon Selphy CP910 Printer Body Replacement: paso 10, imagen 3 de 3
    • Remove the main hard drive from the printer body.
    Pregunta a FixBot
    Agregar Comentario
  11. Canon Selphy CP910 Printer Body Replacement: paso 11, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement: paso 11, imagen 2 de 2
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
    Pregunta a FixBot
    Agregar Comentario
  12. Canon Selphy CP910 Printer Body Replacement: paso 12, imagen 1 de 2 Canon Selphy CP910 Printer Body Replacement: paso 12, imagen 2 de 2
    • The empty case will look like this once all the parts are removed.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Equipo
UW Tacoma, Team 1-6, Rose Winter 2016 Miembro de UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
Miembros de 4
11 Guías creadas
1Guía Comentario
Bien conduit par cette marche à suivre, j'ai réussi à démonter la cartouche bloquée suite à un disfonctionnement des photos .
Le remontage était un peu plus difficile suite à la minutie à apporter auprès du peu de place pour la reconnection. Merci.
Joël vanhooren - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 109
Todo El Tiempo: 6,129
