Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon Selphy CP910 Buttons Replacement
Qué necesitas
  1. Canon Selphy CP910 Buttons Replacement, Body: paso 1, imagen 1 de 2 Canon Selphy CP910 Buttons Replacement, Body: paso 1, imagen 2 de 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
    Pregunta a FixBot
    Agregar Comentario
  2. Canon Selphy CP910 Buttons Replacement: paso 2, imagen 1 de 3 Canon Selphy CP910 Buttons Replacement: paso 2, imagen 2 de 3 Canon Selphy CP910 Buttons Replacement: paso 2, imagen 3 de 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
    Pregunta a FixBot
    Agregar Comentario
  3. Canon Selphy CP910 Buttons Replacement: paso 3, imagen 1 de 3 Canon Selphy CP910 Buttons Replacement: paso 3, imagen 2 de 3 Canon Selphy CP910 Buttons Replacement: paso 3, imagen 3 de 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
    Pregunta a FixBot
    Agregar Comentario
  4. Canon Selphy CP910 Buttons Replacement: paso 4, imagen 1 de 3 Canon Selphy CP910 Buttons Replacement: paso 4, imagen 2 de 3 Canon Selphy CP910 Buttons Replacement: paso 4, imagen 3 de 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
    Pregunta a FixBot
    Agregar Comentario
  5. Canon Selphy CP910 Buttons Replacement, Buttons: paso 5, imagen 1 de 2 Canon Selphy CP910 Buttons Replacement, Buttons: paso 5, imagen 2 de 2
    • Turn the top panel over so the inside faces toward you.
    Pregunta a FixBot
    Agregar Comentario
  6. Canon Selphy CP910 Buttons Replacement: paso 6, imagen 1 de 3 Canon Selphy CP910 Buttons Replacement: paso 6, imagen 2 de 3 Canon Selphy CP910 Buttons Replacement: paso 6, imagen 3 de 3
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
    Pregunta a FixBot
    Agregar Comentario
  7. Canon Selphy CP910 Buttons Replacement: paso 7, imagen 1 de 2 Canon Selphy CP910 Buttons Replacement: paso 7, imagen 2 de 2
    • Carefully remove the frame attached to the screen.
    Pregunta a FixBot
    Agregar Comentario
  8. Canon Selphy CP910 Buttons Replacement: paso 8, imagen 1 de 3 Canon Selphy CP910 Buttons Replacement: paso 8, imagen 2 de 3 Canon Selphy CP910 Buttons Replacement: paso 8, imagen 3 de 3
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
    Pregunta a FixBot
    Agregar Comentario
  9. Canon Selphy CP910 Buttons Replacement: paso 9, imagen 1 de 2 Canon Selphy CP910 Buttons Replacement: paso 9, imagen 2 de 2
    • There is a clear plastic “L” shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
UW Tacoma, Team 1-6, Rose Winter 2016 Miembro de UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
Miembros de 4
11 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 1,239
