Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon Selphy CP720 Paper Cassette Replacement
    1. Canon Selphy CP720 Paper Cassette Replacement, Paper Cassette: paso 1, imagen 1 de 1
      • This configuration allows printing but not reloading of the paper cassette. The cassette needs to be removed before paper can be put inside.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon Selphy CP720 Paper Cassette Replacement: paso 2, imagen 1 de 1
      • Set the printer on its back so that the Paper Cassette sticks straight up in the air.
      • Pull the Paper Cassette out of the printer. It is guided by two studs that fit into the grooves on the underside of the cassette.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon Selphy CP720 Paper Cassette Replacement: paso 3, imagen 1 de 1
      • Slide the translucent top cover of the Paper Cassette back to expose the paper storage area.
      • With the top half pulled back, lift the glossy side and open the Cassette.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon Selphy CP720 Paper Cassette Replacement: paso 4, imagen 1 de 1
      • Put no more than 12 pages in the cassette
      Pregunta a FixBot
      Agregar Comentario
    5. Canon Selphy CP720 Paper Cassette Replacement: paso 5, imagen 1 de 1
      • Slide the upper clear plastic part back by gripping it on either side and pulling it backward.
      Pregunta a FixBot
      Agregar Comentario
    6. Canon Selphy CP720 Paper Cassette Replacement: paso 6, imagen 1 de 1
      • Make sure the metal tab on the printer will fit over base of the cassette to allow the hinged ramp to direct the paper into the rollers.
      Pregunta a FixBot
      Agregar Comentario
    7. Canon Selphy CP720 Paper Cassette Replacement: paso 7, imagen 1 de 1
      • Push the cassette into the printer, with the glossy side up. Make sure that the Cassette is being guided by the studs in the mouth of the printer.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
There, your Selphy CP720 has been loaded with paper.
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 73
Todo El Tiempo: 4,147
