Saltar al contenido principal
Canon Selphy CP720 Cooling Fan Replacement
Qué necesitas
  1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: paso 1, imagen 1 de 2 Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: paso 1, imagen 2 de 2
    • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
  2. Canon Selphy CP720 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Gently lift the top half of the printer off its base
    • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
  3. Canon Selphy CP720 Cooling Fan Replacement: paso 3, imagen 1 de 3 Canon Selphy CP720 Cooling Fan Replacement: paso 3, imagen 2 de 3 Canon Selphy CP720 Cooling Fan Replacement: paso 3, imagen 3 de 3
    • Remove the side panel by lifting it out.
  4. Canon Selphy CP720 Cooling Fan Replacement: paso 4, imagen 1 de 2 Canon Selphy CP720 Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
    • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
  5. Canon Selphy CP720 Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 8mm Phillips #1 screws from the fan.
    • Remove the fan from the panel.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 371
