Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon Selphy CP1200 Print Mechanism Replacement
Qué necesitas
    1. Canon Selphy CP1200 Print Mechanism Replacement, LCD/Buttons: paso 1, imagen 1 de 1
      • Unscrew the four 6mm PH000 corner screws.
      • This will require a screwdriver with a long, narrow shaft.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon Selphy CP1200 Print Mechanism Replacement: paso 2, imagen 1 de 1
      • Unscrew the three 4mm PH1 screws on the bottom of the printer.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon Selphy CP1200 Print Mechanism Replacement: paso 3, imagen 1 de 1
      • Gently pry open the top of the case from either the front or back.
      • A plastic opening tool may help.
      • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon Selphy CP1200 Print Mechanism Replacement: paso 4, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
      • Tweezers may be useful given the limited space between the top assembly and motherboard.
      • The top assembly, containing both the LCD and buttons, will now be completely free
      Pregunta a FixBot
      Agregar Comentario
    1. Canon Selphy CP1200 Print Mechanism Replacement, Motherboard: paso 5, imagen 1 de 1
      • Detach the fan cable from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon Selphy CP1200 Print Mechanism Replacement: paso 6, imagen 1 de 1
      • Detach the ribbon cable leading to the DC in port and battery leads.
      • Tweezers may be useful.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon Selphy CP1200 Print Mechanism Replacement: paso 7, imagen 1 de 1
      • Unscrew the three 3mm PH000 screws from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon Selphy CP1200 Print Mechanism Replacement: paso 8, imagen 1 de 1
      • Disconnect the bundled cables leading to the printing mechanism.
      Pregunta a FixBot
      Agregar Comentario
    5. Canon Selphy CP1200 Print Mechanism Replacement: paso 9, imagen 1 de 1
      • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
      • Tweezers may be useful due to the limited amount of space.
      Pregunta a FixBot
      Agregar Comentario
    1. Canon Selphy CP1200 Print Mechanism Replacement, Print Mechanism: paso 10, imagen 1 de 2 Canon Selphy CP1200 Print Mechanism Replacement, Print Mechanism: paso 10, imagen 2 de 2
      • Open the side door and depress the ink cassette release.
      • Slide out and remove the ink cassette.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon Selphy CP1200 Print Mechanism Replacement: paso 11, imagen 1 de 1
      • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon Selphy CP1200 Print Mechanism Replacement: paso 12, imagen 1 de 1
      • Lift out the print mechanism of the printer case.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
3 personas más completaron esta guía.
1Guía Comentario
Gut, hat geklappt!
Antonina Aroutjunova - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 30
Ultimos 30 días: 118
Todo El Tiempo: 4,879
