Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon Selphy CP1200 LCD/Buttons Replacement
Qué necesitas
    1. Canon Selphy CP1200 LCD/Buttons Replacement, LCD/Buttons: paso 1, imagen 1 de 1
      • Unscrew the four 6mm PH000 corner screws.
      • This will require a screwdriver with a long, narrow shaft.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon Selphy CP1200 LCD/Buttons Replacement: paso 2, imagen 1 de 1
      • Unscrew the three 4mm PH1 screws on the bottom of the printer.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon Selphy CP1200 LCD/Buttons Replacement: paso 3, imagen 1 de 1
      • Gently pry open the top of the case from either the front or back.
      • A plastic opening tool may help.
      • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon Selphy CP1200 LCD/Buttons Replacement: paso 4, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
      • Tweezers may be useful given the limited space between the top assembly and motherboard.
      • The top assembly, containing both the LCD and buttons, will now be completely free
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 1,015
