Saltar al contenido principal
Canon SX40 HS camera Flash Cover Replacement
Qué necesitas
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: paso 1, imagen 1 de 2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: paso 1, imagen 2 de 2
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: paso 2, imagen 1 de 1
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: paso 3, imagen 1 de 2 Canon SX40 HS camera Flash Cover Replacement: paso 3, imagen 2 de 2
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: paso 4, imagen 1 de 1
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
Conclusión
To reassemble your device, follow Steps 1-4 in reverse order.
Una persona más ha completado esta guía.
John Bui
Miembro Desde 03/26/15
352 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 15
Todo El Tiempo: 867
