Saltar al contenido principal
Canon Powershot SX500 IS Control Dial Replacement
Qué necesitas
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: paso 2, imagen 1 de 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: paso 3, imagen 1 de 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: paso 4, imagen 1 de 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: paso 4, imagen 2 de 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: paso 4, imagen 3 de 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: paso 5, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: paso 6, imagen 1 de 1
  7. Canon Powershot SX500 IS Control Dial Replacement: paso 7, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: paso 8, imagen 1 de 2 Canon Powershot SX500 IS Control Dial Replacement: paso 8, imagen 2 de 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: paso 9, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: paso 10, imagen 1 de 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: paso 11, imagen 1 de 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: paso 12, imagen 1 de 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Gracias gracias gracias
edgarlugo20111917 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 452
