Saltar al contenido principal
Canon Powershot SX30 IS LCD Panel Rear Cover Replacement
Qué necesitas
  1. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement, LCD Panel Rear Cover: paso 1, imagen 1 de 1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 2, imagen 1 de 2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 2, imagen 2 de 2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 3, imagen 1 de 3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 3, imagen 2 de 3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 3, imagen 3 de 3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 4, imagen 1 de 2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 4, imagen 2 de 2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: paso 5, imagen 1 de 1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
Conclusión
Ellis DeVoe
Miembro Desde 04/14/15
580 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-12, Maness Spring 2015 Miembro de Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 7
Todo El Tiempo: 330
