Herramientas
Partes
No se especificaron partes.
Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
Remove the last screw (2.59 mm) located on the bottom of the camera.
Slowly pull the back cover of the camera.
Unplug the green and white plugs connecting the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the back tab.
Casi Terminas!
Conclusión
