Saltar al contenido principal
Canon Powershot SD880 Top Panel Replacement
Qué necesitas
  1. Canon Powershot SD880 Top Panel Replacement, Back Cover: paso 1, imagen 1 de 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: paso 1, imagen 2 de 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Top Panel Replacement, Top Panel: paso 2, imagen 1 de 2 Canon Powershot SD880 Top Panel Replacement, Top Panel: paso 2, imagen 2 de 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
Conclusión
Robert Manno
Miembro Desde 01/05/11
444 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,059
