Saltar al contenido principal
Canon Powershot SD880 LCD Display Replacement
Qué necesitas
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: paso 1, imagen 1 de 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: paso 1, imagen 2 de 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: paso 2, imagen 1 de 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: paso 2, imagen 2 de 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: paso 2, imagen 3 de 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Conclusión
Ben Tupas
Miembro Desde 01/13/11
329 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
Un comentario
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,368
