Saltar al contenido principal
Canon Powershot SD880 Flash Replacement
Qué necesitas
  1. Canon Powershot SD880 Flash Replacement, Back Cover: paso 1, imagen 1 de 3 Canon Powershot SD880 Flash Replacement, Back Cover: paso 1, imagen 2 de 3 Canon Powershot SD880 Flash Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Flash Replacement, Front Cover: paso 2, imagen 1 de 3 Canon Powershot SD880 Flash Replacement, Front Cover: paso 2, imagen 2 de 3 Canon Powershot SD880 Flash Replacement, Front Cover: paso 2, imagen 3 de 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Canon Powershot SD880 Flash Replacement, Top Panel: paso 3, imagen 1 de 2 Canon Powershot SD880 Flash Replacement, Top Panel: paso 3, imagen 2 de 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Canon Powershot SD880 Flash Replacement, LCD Display: paso 4, imagen 1 de 3 Canon Powershot SD880 Flash Replacement, LCD Display: paso 4, imagen 2 de 3 Canon Powershot SD880 Flash Replacement, LCD Display: paso 4, imagen 3 de 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
  5. Canon Powershot SD880 Flash Replacement, Flash: paso 5, imagen 1 de 3 Canon Powershot SD880 Flash Replacement, Flash: paso 5, imagen 2 de 3 Canon Powershot SD880 Flash Replacement, Flash: paso 5, imagen 3 de 3
    • Use caution when removing the flash, as the capacitor may still have a charge.
    • Remove two 1.8 mm screws from the back using a Phillips #0 screwdriver to disconnect the metal guard.
    • To unplug the ribbon at the top of the camera, gently pull it from the plug-in point.
    • Disconnect the white plug from the red and black wires.
Conclusión
Robert Manno
Miembro Desde 01/05/11
432 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,569
