Saltar al contenido principal
Canon Powershot SD750 Camera Case Replacement
Qué necesitas
  1. Canon Powershot SD750 Camera Case Replacement, Camera Case: paso 1, imagen 1 de 1
    • Turn the camera to the side that has the attachment for the wrist strap.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Canon Powershot SD750 Camera Case Replacement: paso 2, imagen 1 de 1
    • Remove the plastic subsection by prying it with your fingers.
    • Note: It may be helpful to pry from the bottom of the camera with the battery door open.
    • The wrist strap attachment behind the subsection will come loose and may fall out.
  3. Canon Powershot SD750 Camera Case Replacement: paso 3, imagen 1 de 1
    • Turn the camera over to the side opposite of the wrist strap.
    • Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
  4. Canon Powershot SD750 Camera Case Replacement: paso 4, imagen 1 de 1
    • Flip the camera upside down.
    • Remove the following screws with a #00 Phillips screwdriver.
    • One black 3.4 mm Phillips screw.
    • One silver 3.4 mm Phillips screw.
    • NOTE: Using your fingernails may help in removal.
  5. Canon Powershot SD750 Camera Case Replacement: paso 5, imagen 1 de 1
    • Place the camera on the side opposite of the wrist strap handle.
    • Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
    • Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
    • Note: A rubber foam washer that separates the lens from the casing will fall off when the case is removed. Be sure to store it safely.
    • Note: When reassembling ensure the back plate screw tabs are over the wrist strap attachment and the front plate screw tabs go under orange casing.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 14-37, Forte Fall 2010 Miembro de Cal Poly, Team 14-37, Forte Fall 2010
CPSU-FORTE-F10S14G37
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 24
Todo El Tiempo: 3,823
