Saltar al contenido principal
Canon Powershot SD550 Outer Case Replacement
Qué necesitas
  1. Canon Powershot SD550 Outer Case Replacement, Outer Case: paso 1, imagen 1 de 1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Outer Case Replacement: paso 2, imagen 1 de 1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Outer Case Replacement: paso 3, imagen 1 de 3 Canon Powershot SD550 Outer Case Replacement: paso 3, imagen 2 de 3 Canon Powershot SD550 Outer Case Replacement: paso 3, imagen 3 de 3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Outer Case Replacement: paso 4, imagen 1 de 3 Canon Powershot SD550 Outer Case Replacement: paso 4, imagen 2 de 3 Canon Powershot SD550 Outer Case Replacement: paso 4, imagen 3 de 3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Outer Case Replacement: paso 5, imagen 1 de 3 Canon Powershot SD550 Outer Case Replacement: paso 5, imagen 2 de 3 Canon Powershot SD550 Outer Case Replacement: paso 5, imagen 3 de 3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Outer Case Replacement: paso 6, imagen 1 de 3 Canon Powershot SD550 Outer Case Replacement: paso 6, imagen 2 de 3 Canon Powershot SD550 Outer Case Replacement: paso 6, imagen 3 de 3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
Conclusión
Matthew Theiss
Miembro Desde 04/14/11
191 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-23, Garner Spring 2011 Miembro de Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,595
