Introducción
The flash bulb is essential for to take dimly lit photographs. If the flash goes out, your camera will have severely limited functionality.
Qué necesitas
Peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the 2.9 mm screw in the top left corner.
Rotate the screen clockwise until it lifts away from the camera.
Once the image sensor is removed, turn the camera over and find the screw in the bottom right corner.
Remove this .01 inch screw to free the ribbon cables.
