Saltar al contenido principal
Canon Powershot Pro1 Motherboard Replacement
Qué necesitas
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: paso 2, imagen 1 de 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: paso 3, imagen 1 de 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: paso 4, imagen 1 de 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: paso 5, imagen 1 de 3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: paso 5, imagen 2 de 3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: paso 5, imagen 3 de 3
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: paso 6, imagen 1 de 3 Canon Powershot Pro1 Motherboard  Replacement: paso 6, imagen 2 de 3 Canon Powershot Pro1 Motherboard  Replacement: paso 6, imagen 3 de 3
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: paso 7, imagen 1 de 3 Canon Powershot Pro1 Motherboard  Replacement: paso 7, imagen 2 de 3 Canon Powershot Pro1 Motherboard  Replacement: paso 7, imagen 3 de 3
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: paso 8, imagen 1 de 2 Canon Powershot Pro1 Motherboard  Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  9. Canon Powershot Pro1 Motherboard  Replacement: paso 9, imagen 1 de 3 Canon Powershot Pro1 Motherboard  Replacement: paso 9, imagen 2 de 3 Canon Powershot Pro1 Motherboard  Replacement: paso 9, imagen 3 de 3
    • Once detached from all connectors and ribbon cables, remove the motherboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 991
