Saltar al contenido principal
Canon Powershot Pro1 Lens Replacement
Qué necesitas
  1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: paso 1, imagen 1 de 2 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: paso 1, imagen 2 de 2
    • Have the lens of the camera facing upwards.
    • Find the red plastic ring.
    • Look for two small opening above the red plastic ring.
    • Reference to the left of the picture and you will see the orange square.
  2. Canon Powershot Pro1 Lens Replacement: paso 2, imagen 1 de 3 Canon Powershot Pro1 Lens Replacement: paso 2, imagen 2 de 3 Canon Powershot Pro1 Lens Replacement: paso 2, imagen 3 de 3
    • Remove the plastic ring that has a red strip.
    • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
  3. Canon Powershot Pro1 Lens Replacement: paso 3, imagen 1 de 3 Canon Powershot Pro1 Lens Replacement: paso 3, imagen 2 de 3 Canon Powershot Pro1 Lens Replacement: paso 3, imagen 3 de 3
    • Place the camera on its back with the lens facing upwards as shown in the image
    • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
    • Remove the screw by turning the Philip driver counterclockwise.
    • By removing the screw, you will be able to remove the cover lens.
  4. Canon Powershot Pro1 Lens Replacement: paso 4, imagen 1 de 1
    • Use the nylon spudger to remove the ring holding the lens in place.
    • Pull gently until the lens ring snaps off.
  5. Canon Powershot Pro1 Lens Replacement: paso 5, imagen 1 de 1
    • Refer to the left-hand pictere to see what the len's ring looks like.
  6. Canon Powershot Pro1 Lens Replacement: paso 6, imagen 1 de 3 Canon Powershot Pro1 Lens Replacement: paso 6, imagen 2 de 3 Canon Powershot Pro1 Lens Replacement: paso 6, imagen 3 de 3
    • Take out the lens once the plastic ring is removed
    • Hold the outer layer of the lens to not create smudges on it.
    • Replace the lens and follow the instruction in reversed order to reassemble the camera.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 42
Todo El Tiempo: 2,946
