Saltar al contenido principal
Canon Powershot Pro1 Flash Replacement
Qué necesitas
  1. Canon Powershot Pro1 Flash Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Flash Replacement: paso 2, imagen 1 de 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Flash Replacement: paso 3, imagen 1 de 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Flash Replacement: paso 4, imagen 1 de 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Flash Replacement, Flash: paso 5, imagen 1 de 2 Canon Powershot Pro1 Flash Replacement, Flash: paso 5, imagen 2 de 2
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
  6. Canon Powershot Pro1 Flash Replacement: paso 6, imagen 1 de 1
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
  7. Canon Powershot Pro1 Flash Replacement: paso 7, imagen 1 de 1
    • Use the plastic spudger to remove the upper portion of the flash housing.
  8. Canon Powershot Pro1 Flash Replacement: paso 8, imagen 1 de 3 Canon Powershot Pro1 Flash Replacement: paso 8, imagen 2 de 3 Canon Powershot Pro1 Flash Replacement: paso 8, imagen 3 de 3
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
  9. Canon Powershot Pro1 Flash Replacement: paso 9, imagen 1 de 1
    • Cut the flash and capacitor cables with a wire cutter.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 871
