Saltar al contenido principal
Canon Powershot Pro1 Battery Replacement
  1. Canon Powershot Pro1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Battery Replacement: paso 2, imagen 1 de 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Battery Replacement: paso 3, imagen 1 de 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Battery Replacement: paso 4, imagen 1 de 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,126
